    Scale Strokes and Effects
    63 Posts 12 Posters 158.2k Views 9 Watching
      @Boldline It looks like a bug — scaling with the object doesn't work for strokes aligned to inside or outside.
        @b77 Yes! When I moved the stroke back to the center-align, it scales correctly now. thanks.
        @vectoradmin - would you prefer I move this over the the "bug report" section as it's own thread or leave it here?
          @Boldline @b77 @Victor-Vector The aligned stroke scaling is a regression (from two builds ago). I added it to the backlog (no need to move the post).
            VectorStyler @danegeld
            @danegeld A new option in build 1.1.024: Transform Stroke in the Appearance panel menu, must select object in the panel (also in Object Options).
            Will transform all subsequent stroke attributes inside that object
              @vectoradmin this works well for customizing it on an individual file and individual object level, but is there a way to make scaling stroke size with object the default so that we're not having to go in to change the setting with every be document?
                @Boldline said in Scale Strokes and Effects:
                No such feature now, but I think one could be made for new objects.
                  @vectoradmin Only speaking for myself, I rarely want to stroke to stay the same size when I am scaling things - typically I design with the stroke being sized in relation to the fill object it's attached to. So selfishly, I'd prefer VS default to scaling strokes and effects and let the new option in the appearance panel allow that selected object and future objects on that document be the opposite.
                  To appease all, I'd love to see it as a new document setup/document setup toggle. and the opposite takes affect if you go in and manually modify the setting in the appearance panel
                  I don't know if that's feasible
                  • Victor VectorV Offline
                    Victor Vector @Boldline
                    I too would prefer the stroke to be scalable by default, and yes, having an option in the "New Document Setup" and/or in "Preferences", for the users to decide how they would like to roll, is a nice way to handle this. I think AI had this in their preferences, but I cannot remember as it was a long time ago, haha.
                    I still think Transformed Stroke (scale stroke with object) needs to be more accessible rather than in a panel menu. Would it be helpful to also have it in the Stroke panel, next to the Width field?
                    • J Offline
                      Jayanta Das
                      Is scale stroke with object works for you guys? It is not working here.
                      Recording
                      Mac Mini M4 Pro | 24Gb
                      WIndows 11 | Intel i5 11Gen
                      Wacom Intuos Pro
                        b77 @Jayanta Das
                        @Jayanta-Das It looks like 'Scale Image Filters' needs to be enabled as well.
                        @VectorStyler Is this by design?
                        • J Offline
                          Jayanta Das @b77
                          @b77 Doesnot work here. I enabled both Scale Stroke and Scale Image Filters. Scale Image Filter stays selected but Scale Stroke disable (in panel menu) once I deselect the object
                          Wacom Intuos Pro
                            b77 @Jayanta Das
                            @Jayanta-Das It works here, at least on the Mac: https://recordit.co/YXpYX5IyfR
                            • J Offline
                              Jayanta Das @b77
                              @b77 I think its Windows only issue.
                              Wacom Intuos Pro
                                Subpath @Jayanta Das
                                @Jayanta-Das
                                Is working here (win 10) even that image filter and Stroke scaling
                                are not enabled when I duplicate a shape with both enabled.
                                Strange its all ok in the video.
                                Could also deselect and select the Shape, is still fine.
                                But, with no offense. I find this a very curious way to
                                enable a simply stroke scaling and (sorry) very cumbersome.
                                And you have to do this for every new Shape.
                                Video see here
                                • J Offline
                                  Jayanta Das @Subpath
                                  @Subpath Thanks.
                                  I think I got the reason for the issue. I was selecting the stroke in appearance panel and then in the menu enabling Scale Stroke. That gives me the issue. Without selecting the
                                  Stroke in the appearance panel It works. In this thread @VectorStyler said to select Stroke in the appeance panel so I was doing that.
                                  Here is the recording of two shape. On the other one I select Stroke in appeance and then enable Scale Stroke which doesn't work.
                                  Wacom Intuos Pro
                                  S VectorStylerV 2 Replies Last reply Reply Quote 2
                                    @Jayanta-Das , glady
                                    nice that it was helpful and thanks for your info too
                                      VectorStyler @Jayanta Das
                                      @Jayanta-Das said in Scale Strokes and Effects:
                                      Yes, the "Transform Stroke" works when the Object row is selected in the Appearance panel. Should be grayed out when the style is selected (or should fall back to the object automatically). Will fix this.
                                      • ? Offline
                                        A Former User @VectorStyler
                                        I agree with others that the Transform Stroke should be available per object or per stroke and visible as an icon for a single click.
                                        "Per object" could override the "per stroke" or reset it.
                                        In the panel menu I see "Transformed stroke" not "Transform stroke", is that something else?
                                        Is there a PROPORTIONAL STROKE SCALING available? Like, I select 3 objects with a different stroke and want all of strokes to scale proportionally? I think currently all of these gonna get the same width.
                                        Keeping the stroke size while scaling an object and the proportional stroke scaling is useful for cartooning or text based designs. I use the 1st one a lot in Affinity to keep the stroke consistent, it's a one click icon. The second one is not available.
                                          VectorStyler @Guest
                                          @plrang said in Scale Strokes and Effects:
                                          This is available now, but it is a non-destructive option.
                                          Yes, it can be set per object, but if it is set for a Layer or Group, then it will be enabled for all members.
                                          Yes, it is "Transformed Stroke", and the reason for this name is that instead "transforming" the stroke, it just enables a flag, that the object (or member objects) stroke should be "transformed", whenever the object (or parent) is transformed. Turning it off, will return to the original stroke width.
                                          Since it is a non-destructive option, scaling the object proportionally will scale all strokes proportionally. But when changing the stroke width (setting it from the panel), it will set the same width.
                                          Both the first and the second mode should work in VS. But it is important to know, that when the object is scaled, the stroke width value will never be scaled. Instead, the stroke is displayed using all the transforms on the object and its parent objects.
                                          I think an icon in the stroke panel could help. Also, maybe VS should have destructive stroke scaling? changing the actual stroke width values, instead of just "virtually" adjusting them?
                                          • ? Offline
                                            @VectorStyler I know it's available.
                                            I just wanted to address the availability of a permanent button in the view since it's one of the main and fundamental properties of the stroke IMO.
                                            I have no idea how it's organized in VectorStyler, but if that proportional stroke scaling (without scaling shapes containing it) would need those actual stroke values, seems like something I had in mind while asking.
                                            Say I have a head, eyes, nose etc, and I want to make their strokes proportionally thicker, is that available?
                                            If not, that's what I am talking about.
