    Expanded and Divided Boolean results creates less than desired results
    12 Posts 3 Posters 11.4k Views 2 Watching
      @Boldline Tried to replicate this with a similar case, but it is working here. If you have an example where expanding and then dividing has undesirable results, please send it to me.
        Did a few Tests, no problems here.
        Win 10
          @VectorStyler @Subpath - Thank you both for testing it - I may not have been communicating fully about the issue. After I divide and remove unwanted sections of overlap, merging the formerly divided sections back together again causes unclean results.
          Here is an example of me doing this with the pen tool. I create the lines and create overlapping lines, then expand them and divide, then re-unite the ones I want merged together. The results here are what I get with every attempt, though sometimes it's worse than what you see here.
            There's always a small gap where the divide occurs and that gaps is not always fully closed up when merge or unite is applied.
            Here is a pic showing that small white gap on strokes that were expanded and then divided:
            0_1652794721167_5af6b9cd-d4fc-4bfb-84f2-c94ff894fdb0-BLD 2022-05-17 at 09.36.59.png
            Using the same example as the image above, I grabbed the sections of pink expanded path in the same direction as the blue line I added and attempted to merge them. The top seam merged perfectly (1) and the bottom seam did not merge at all (2)
            0_1652794872040_ff2ec0b6-7193-480b-8aee-7099aa8060f0-BLD 2022-05-17 at 09.39.30.png
            Sometimes they do merge perfectly - but it's not common for me, especially if I am using tapered lines or different angles.
            Here's a common result I get from merging previously divided shapes: I have to go in to each one like this and delete out the extra nodes and that becomes time consuming.
            0_1652795403166_51f48d87-c847-4276-a836-b236b644cdbf-BLD 2022-05-17 at 09.48.51.png
              Boldline @Boldline
              @VectorStyler if you follow the steps in the examples above, are you able to replicate the gaps after dividing and the semi-united results after using merge/unite? If not I can send you some before and after examples
              thanks for looking into all this
                Could confirm it now.
                I think I have a solution/workaround for you.
                As you may know, I have been playing a bit with the
                Offset path Shape Effect, so I came up with this solution.
                Before you merge your lines back together, put a small offset around the shapes
                so the little gaps will disapear. Use 0.5 pt or less. I don't know how important
                correct size is for you design. Maybe you can consider the size of the offset?
                Video: This is how I did it
                Bevor:
                after: ( no more hassle 🙂 )
                  Boldline @Subpath
                  @Subpath that's a great solution! thanks for sharing. i will try doing that.
                  Hopefully @VectorStyler can still find improved ways for the merge and union to work with divided shapes because it occurs in other scenarios as well, but for now it's great to have a quick way to fix it in the moment
                  S VectorStylerV 2 Replies Last reply Reply Quote 1
                    Subpath @Boldline
                    Great that it is helpful. Also useful for my cases of course.
                    Btw as you know you could also create a Action to apply
                    that Shape Effect.
                      Boldline @Subpath
                      @Subpath said in Expanded and Divided Boolean results creates less than desired results:
                      that Shape Effect.
                      I could probably add the merge to the action along with the offset path and make it easier that way as well
                        @Boldline Yes, merge still has some issues with precisely touching shapes. Will try to improve this.
                          @VectorStyler thank you for looking into it and doing what you can to improve it
