condensing file name extension
  • I was just curious if you'd considered or were able to condense the extension for VS files to ".vs" instead of "vstyler"? short and sweet like ".ai", ".cdr", etc
    Also is it on the list to eventually offer quick previews of VS files? - so on Mac, hitting the space bar on a selected file shows you the preview?
    @Boldline The quick preview is in the backlog.
    About having the shorter extension, I have to check if that is used by someone else.
    Having the longer extension (nowadays) is affordable, and has the advantage that it will not collide with something else.
    But I'm open to change.
  • @vectoradmin sounds good on both - do what is most affordable so VS can keep growing and getting better known
