Dropping colors on selected objects
I'm not sure if this is a bug. When the document color mode is CMYK you can't select different colors from the pallet panel to drag them to the selected objects. In RGB mode this is working.
@FastVector I tried to replicate this, but it worked here. It might be that I misunderstand the issue.
What I did:
- with a CMYK document
- selected multiple objects
- then selected multiple colors in the palette
- drag&drop these into the selection
- each object gets a color from the dropped colors (in order of selection).
Yes that are the steps I also took. Now I tried the document pallete and then it is working in the CMYK mode. So I quess the problem is somewhere in my own palletes, I don't know what exactly...
Here one of the color palletes
Tried to make some new palletes in the CMYK mode, but the problem still remained.
@FastVector The issue is with external palettes.
I will fix this ASAP.
@FastVector In the (external) color palette panel menu, uncheck "Register Color".
When this option is enabled, the palette cannot select multiple colors.
@VectorStyler This option was already disabled.
@FastVector this is what I get: https://share.cleanshot.com/3V791MX7
@VectorStyler I get this only when I'm working in the RGB mode. When I'm in the CMYK document mode I can only select the colors in the pallete panel when there are no objects selected. When I select the objects you can only change the color with one single color.
@FastVector I managed to replicate the error.
I saw that in the new update the problem is solved. Thx
