update 1.2.030
    VectorStyler 1.2.030 release notes
    • Added a global color mode option to generate color palettes for new documents.
    • Added copy and paste commands to the shape preset drop down for easier shape transfer.
    • Fixed a global color handling bug.
    • Fixed a template artboard refresh issue.
    • Fixed a template selection issue with duplicate templates.
    • Default artboard size can also be set in Canvas options.
    • Update the offset path indicator in wireframe mode.
    • Added support for Unicode extension planes in TTF fonts.
    • Improved handling of shape closing in the path sketch tool.
    • Editable text inside compound shapes.
    • Drag and drop improvements in the Layers panel.
    • Do not open large preview when dragging from the layer preview icon.
    • Composite shape operator in menu to show selected mode.
    • Erase block modifier to work on selected shapes only.
    • Mirror tool to position objects correctly.
    • Allow selection and copy from Unicode field in the glyph panel.
    • Indicate empty layers and groups in the Layers panel with a different opening icon.
    • Improved handling of stroke attributes in the Pencil tool.
    • Option to move locked objects when moving artboards.
    • Duplicating artboards from the canvas panel to consider bleed for spacing.
    • Document level option to not show fill for open paths.
    • Added alternate editor modes to the reflect and corner tools.
    • Improved Transform panel layout.
    • General stability improvements.
  • @VectorStyler Very nice. Looking forward to updating.
  • @VectorStyler Keep up the great work! I appreciate the consistent updates and improvements to VS
