Can shapebuilder to only fill the negative space?
How do I change the shapebuilder to only fill the negative space, not create one solid shape with the negative and positive space? Here is a video of me attempting to fill the interior portion of the coffee cup. The outline of the cup is a solid fill vector.
@Boldline Send me that file by email.
@Boldline Try 'Reverse Path Direction' (Ctrl-I) before using Shape Builder.
@b77 This solved the problem! thank you.
@VectorStyler I'll still send the file over to you
@Boldline Got the file, I will try to fix this ASAP.
