Could print panel settings be made sticky?
Each time my customer prints films from VS, he has to reset the paper size information each time he re-opens VS. Could there be an option to save a print profile or an option to leave all settings the same unless the user presses a "reset to default"?
@Boldline The printing options can be saved as presets, both into the document or as global presets (Presets dropdown).
Also, if the document is saved after printing, the printing options are saved with the document and are used next time. (and there is the Print Again command, that uses these last options).
