Copying and pasting path segments
Using the Shape Editor Tool I can select and cut or copy a path segment but cannot do any pasting...
I am thinking that the Shape Editor Tool exhibits the same traits as the Direct Selection Tool in AI?
if your Path is a closed one, then open it
and try againif i remember right i once find out that
copy and paste a segment of a Path work
only on a open Pathtry this way to copy a segement on a open path:
select your segment
copy it
deselect your path
and paste that segment
@Subpath said in Copying and pasting path segments:
and try againThank you @Subpath and I was actually working on an open path... It's not working.
@William-Kansepa said in Copying and pasting path segments:
please read my previous comment again
i extend it a bit
@Subpath It would make a lot of sense if it would work that way, but it's not...
its working here this way
here a video
@Subpath thank you so much for the video. Yes, I see it's working I probably need to have a look at my settings!
@Subpath @William-Kansepa
Interesting. For me:- Draw an open shape with the Pen tool,
- switch to the Shape Editor,
- select a few nodes,
- CTRL +C,
- switch to the Transform Tool,
- deselect the shape,
- CTRL + V.
The copied path is available to manipulate.
@Victor-Vector said in Copying and pasting path segments:
- CTRL +C,
- CTRL + V.
I got it now... phew. I was selecting the segment directly not the nodes. I am so used to the AI method my bad. In AI you can select either the segment or points and it will work.
Everything is working as expected now. Thank you @Subpath @Victor-Vector.
God I love this forum
@William-Kansepa , @Victor-Vector
btw. if you are a bit adventurous like me
something like this is also possible
see video here
Similar, yes.
And for pasting a copied path section: select a node (preferably an ending node) and the path is pasted as a continuation there.
Otherwise, it is pasted as a new object.
