Image Tracing Preview
I rarely use Image tracing. But while checking Inkscape upcoming version I like how its image tracing works.
https://recordit.co/8LW9G5twQJ
Can It be in done in VS?
@Jayanta-Das I'm not sure if this is feasible. In VS tracing may take some time (especially for color images).
Currently, after adjusting the settings, an extra click on "Trace" is needed. Since the resulting object is a "live" trace object, any further adjustments are possible.
Maybe if the "Trace" button click is not required, then it would work like in the recording.
@Jayanta-Das No offense intended, but I can't see how that is a super effective way to do a vector trace. It seems really imprecise. Wouldn't it make more sense to be able to decide the colors you want it to be? What kind of traces are you typically doing that require adjusting the ratio like that in inkscape?
I have been using a program called "Vector Magic" for a few years and they have a pretty effective way of choosing the colors ahead of time - I mentioned it in a post here
@Boldline Ya the tracing is not so precise, may be it is because of the image type or may be because it is in alpha. What I am asking about was live tracing. And it seem there is some other option also for color tracing, but how precise I don't know.
