Snapshop menu label
The menu item "Snapshot name" label isn't all that great. I would prefer something like New snapshot.
This is from Adobe Lightroom Classic - they call it New Snapshot - they also insert the current time and date marked as an active selection, so if you don't want date and time just typing something else deletes it instantly from the dialog. Date and time is often good enough - one gets tired of describing the snapshop after making just a few.
@Ingolf This is doable, added it to the backlog.
@Ingolf This problem should be fixed in build 1.1.024
@vectoradmin In Windows just a blank field?
@Ingolf I only changed the "name" of the menu item.
Should there be a default snapshot name also? forgot about that
@vectoradmin said in Snapshop menu label:
Should there be a default snapshot name also? forgot about thatIn theory yes, like in Lightroom. I never have a name for the snapshop, the time is usually a good hint.
