Saving Files when Quitting VS should correspond with visual of each open file individually
When VS is quit with unsaved files open, it brings up the "do you want to save before closing?" dialog box which is normal, expected and good. Where it catches me off-guard is that VS does not link the save dialog box with the file - so unless I'm being vigilant in what file name the dialog box is referencing, it's too easy to save or not save when you intended the opposite.
I would prefer it be more like what Illustrator offers - a new dialog box appears for each open and unsaved file and the corresponding design is also brought to the forefront. It provides a good safety check - I can use the name of the file listed in the save option dialog box and/or confirm I am saving or not saving the right file based on a visual check.
@Boldline The Save alert, should bring forward the document it refers to. At least it does here both on Mac and Windows
