Usability: corner tool
 Nicely implemented corner tool. Request: -
When adjusting build in shapes activating the corner tool should adjust all corners and double clicking a corner node should then enable single mode (this is how it works now)
Improvement: When adjusting any other node activating the corner tool should be activated in single edit mode (with the orange border)!
 I draw a lot with the pen tool - almost exclusively - and every time I select the corner tool it will unfortunately adjust all sharp corners in my drawing so every time I want to round or tweak a corner I have to select the single edit mode (orange). Sometimes I forget this because I am zoomed deeply in and do not discover that many corners were adjusted. I then save. Work. Later discover a LOT of rounded corners. Boom. Come to think of it this is an important request.
 @Ingolf There is an option for this: enable Preferences -> Editing Options -> Single Corner Adjustment.
 In this mode, clicking and dragging a corner will always adjust a single corner.
 Alt+dragging adjusts all corners.
 @vectoradmin Thanks!
