    VectorStyler Manual | PDF
    70 Posts 10 Posters 240.8k Views 9 Watching
      @vectoradmin no problem - minor one in the "shape paint" section.
      "Original"
      0_1641278430754_868c69bd-94be-4453-a707-09ce9fcad8ea-BLD 2022-01-04 at 01.38.20.png
        freggern
        @vectoradmin There is a wrong link on the page https://www.vectorstyler.com/documentation/repeater/ unter the overview headline
        • "Not Found" (404) at link https://www.vectorstyler.com/documentation/repeater/geometry/ (from https://www.vectorstyler.com/documentation/repeater/) => correct link is/repeater/geometries/
          VectorStyler @freggern
          @freggern Should be fixed now!
            freggern
            New update of the manual (https://k00.fr/xucgr0j9)
            • Support for internal links (When you click on a link to another chapter, it jumps to the correct chapter of the PDF)
            • & display now correct as &
            • Fix rendering of images as part of an HTML p element
            Included changes of the HTML pages (thx @vectoradmin)
            • Added! What is new in VectorStyler 1.1
            • Correct an internal link
            BoldlineB S 3 Replies Last reply Reply Quote 6
              Boldline @freggern
              @freggern Love that you've taken on the task to do this - thanks! It keeps getting better all the time
                Subpath @freggern
                @freggern
                i am also really gratefully for your work 👍 👍 👍
                  Boldline @freggern
                  @vectorstyler @freggern should we move the PDF file of the documentation over to a pinned thread in the general discussion? This way it's easy to find each time @freggern updates it? Right now it's within an random question and would be harder to go back and find later on.
                    @Boldline A pinned thread in "Tutorials" or "General Discussion" will do.
                      freggern
                      @Boldline @vectoradmin I change the first post and rename the thread title. @vectoradmin Feel free to pin the thread.
                        freggern
                        Is it intentional that the category tutorial is private. So only logined user can see the category or access threads in it?
                          @freggern Should be fixed now.
                            👍 to both Ideas.
                            I was also not so happy that the Tutorials could
                            only be read by registered forum users.
                            Found interested People unnecessarily excluded.
                              freggern
                              • tables now support to hide the first column of the modifier-tables (is hidden on the website per CSS-rule)
                              • column and row now separated by lines
                              • there was a bug where it was possible that fields get combined.
                              • redesign the info box
                              • disable all separator lines
                              • fix a bug where \ in the text doesn't display correct
                              • add 1 cm to the textlinewidth
                              • Updated some images like color palette and layer panel
                              • Add shortcuts
                              1 Reply Last reply Reply Quote 7
                                freggern
                                New update, only include changes of the HTML pages (thx @vectoradmin) - (https://k00.fr/xucgr0j9).
                                • Add shortcuts
                                  freggern
                                  New update with all the changes @vectoradmin did to the documentation.
                                  • Added: Shape Effects -> Outline -> Node Bump
                                  • Added: Path Panal -> Describe fourth row
                                  • Updated: Images for like Preferences
                                  • Update Shortcuts (was already in an unannounced release of the PDF manual)
                                  • Typos
                                    @freggern You're doing an awesome job keeping the pdf manual updated and available. thank you for all your hard work.
                                    A spacing issue I wanted to bring to your attention - not sure if there's an easy fix.
                                    i noticed a few cases in the table of contents, especially as the number switch from two digits to three -the space gets tight and the letters join together.
                                    further down there's some similar spacing issues as the secondary numbers hit three digits
                                    0_1647966738302_ba205407-dc4e-47ed-a502-95e712e6d0b5-BLD 2022-03-22 at 12.30.05.png
                                      freggern
                                      @Boldline I updated the PDF with a different spacing configuration for the TOC, so the overlap should not happen anymore.
                                        Boldline @freggern
                                        @freggern That looks so much better - thanks for getting that fixed up.
                                          freggern @Boldline
                                          @Boldline 👍 If you notice something else or have another idear to improve, let me know.
                                            freggern
                                            New bigger Update:
                                            Content
                                            • Thanks to @Victor-Vector I added the Boolean Operations Reference Guide Images to the PDF-Manual. More information here: https://www.vectorstyler.com/forum/topic/1758/boolean-operations-reference-guide
                                            A lot of redesigns
                                            In this update, I focus on the design that I duck out because of needed code changes of the import script.
                                            • Redesign the chapter title at the beginning of a chapter
                                            • Redesign completely the tables to a modern design and support for table headers (when exists)
                                            • Redesign the information boxes that it match to the table and chapter design
                                            • Update the title page with a date and sources, and adjust the size of the title.
                                            • Update the page header
                                            Bugs
                                            • Fix a bug in the table
                                            Victor VectorV 1 Reply Last reply Reply Quote 3
