    VectorStyler Manual | PDF
    70 Posts 10 Posters 240.8k Views 9 Watching
      freggern
      It depends on where the error or misspelling can be found. I only need to know when it happens only in the pdf file. I can do nothing when the misspelling is on the documentation website. I generate the pdf file in 3 steps that I trigger: Crawl the website, generate a latex file with python out of the website files and then generate the pdf file from the latex file. I don't plan to manually fix misspelling or errors that can be found in the website files. I can only fix "errors" that happend in the process of generating the pdf file.
      Like for example on my todo list:
      • & like Canvas & Artboard doesn't show as Canvas & Artboard
      • Color Palette Bar has some not correct rendered images
      • SVG EFFECTS - Diffuse Light has some not correct rendered images
      • Better floating positioning for images
      • Support for intern links in the pdf
        @Boldline Let me know if there are spelling errors in the documentation.
        You can also post it here.
          @vectoradmin no problem - minor one in the "shape paint" section.
          "Original"
          0_1641278430754_868c69bd-94be-4453-a707-09ce9fcad8ea-BLD 2022-01-04 at 01.38.20.png
            freggern
            @vectoradmin There is a wrong link on the page https://www.vectorstyler.com/documentation/repeater/ unter the overview headline
            • "Not Found" (404) at link https://www.vectorstyler.com/documentation/repeater/geometry/ (from https://www.vectorstyler.com/documentation/repeater/) => correct link is/repeater/geometries/
              VectorStyler @freggern
              @freggern Should be fixed now!
                freggern
                New update of the manual (https://k00.fr/xucgr0j9)
                • Support for internal links (When you click on a link to another chapter, it jumps to the correct chapter of the PDF)
                • & display now correct as &
                • Fix rendering of images as part of an HTML p element
                Included changes of the HTML pages (thx @vectoradmin)
                • Added! What is new in VectorStyler 1.1
                • Correct an internal link
                BoldlineB S 3 Replies Last reply Reply Quote 6
                  Boldline @freggern
                  @freggern Love that you've taken on the task to do this - thanks! It keeps getting better all the time
                    Subpath @freggern
                    @freggern
                    i am also really gratefully for your work 👍 👍 👍
                      Boldline @freggern
                      @vectorstyler @freggern should we move the PDF file of the documentation over to a pinned thread in the general discussion? This way it's easy to find each time @freggern updates it? Right now it's within an random question and would be harder to go back and find later on.
                        @Boldline A pinned thread in "Tutorials" or "General Discussion" will do.
                          freggern
                          @Boldline @vectoradmin I change the first post and rename the thread title. @vectoradmin Feel free to pin the thread.
                            freggern
                            Is it intentional that the category tutorial is private. So only logined user can see the category or access threads in it?
                              @freggern Should be fixed now.
                                👍 to both Ideas.
                                I was also not so happy that the Tutorials could
                                only be read by registered forum users.
                                Found interested People unnecessarily excluded.
                                  freggern
                                  • tables now support to hide the first column of the modifier-tables (is hidden on the website per CSS-rule)
                                  • column and row now separated by lines
                                  • there was a bug where it was possible that fields get combined.
                                  • redesign the info box
                                  • disable all separator lines
                                  • fix a bug where \ in the text doesn't display correct
                                  • add 1 cm to the textlinewidth
                                  • Updated some images like color palette and layer panel
                                  • Add shortcuts
                                  1 Reply Last reply Reply Quote 7
                                    freggern
                                    New update, only include changes of the HTML pages (thx @vectoradmin) - (https://k00.fr/xucgr0j9).
                                    • Add shortcuts
                                      freggern
                                      New update with all the changes @vectoradmin did to the documentation.
                                      • Added: Shape Effects -> Outline -> Node Bump
                                      • Added: Path Panal -> Describe fourth row
                                      • Updated: Images for like Preferences
                                      • Update Shortcuts (was already in an unannounced release of the PDF manual)
                                      • Typos
                                        @freggern You're doing an awesome job keeping the pdf manual updated and available. thank you for all your hard work.
                                        A spacing issue I wanted to bring to your attention - not sure if there's an easy fix.
                                        i noticed a few cases in the table of contents, especially as the number switch from two digits to three -the space gets tight and the letters join together.
                                        further down there's some similar spacing issues as the secondary numbers hit three digits
                                        0_1647966738302_ba205407-dc4e-47ed-a502-95e712e6d0b5-BLD 2022-03-22 at 12.30.05.png
                                          freggern
                                          @Boldline I updated the PDF with a different spacing configuration for the TOC, so the overlap should not happen anymore.
                                            Boldline @freggern
                                            @freggern That looks so much better - thanks for getting that fixed up.
