    Bug List for Version 1.3
    86 Posts 4 Posters 18.3k Views 4 Watching
      VectorStyler @monsterfox
      If you import these two files into Illustrator and VS respectively
      Can you reupload these two SVG files, I'm not sure if I tested with the same.
        monsterfox @VectorStyler
        @VectorStyler picture.dxf.zip Both files become smaller after import, so the size is not correct. Also, if you use the drag-and-drop method, one of the files cannot perform this operation. Please test it again.
          @monsterfox Also send me a VectorStyler file with these files imported (I want to check the result of importing as it happens for you).
            @monsterfox
            These are the VS files I get with importing the DXF files:
            22.vstyler
            Picture.DXF.vstyler
            In Adobe Illustrator 2026:
            the "22.dxf" file imports and has the same size as in VS: width 223.8 pt, height 208 pt
            Illustrator cannot import or open the "Picture.DXF.dxf" file
              @VectorStyler https://www.youtube.com/watch?v=eBK79FwTJhQ
              BUG.vstyler
                @monsterfox The VS document is in MM the Illustrator in PT
                78.96 mm is about 223.83 pt
                  @VectorStyler No, both of my software are set to MM as the unit.
                  https://youtu.be/QGbnutySYEo
                    @monsterfox I will have to review the DXF format to see how the units are handled. I reopened this bug.
                      @VectorStyler https://youtu.be/ZfK73KvZJkY
                      The issue with importing DXF files has now been resolved. The only remaining problem is that when exporting to DXF, the size of the original geometry is incorrectly scaled up. This has been tested across multiple software versions, and the same result occurs every time.
                        @monsterfox I will try to fix this
                          @VectorStyler 2aa71e2f-fa48-41e3-9e2d-da9bed3cb17a-image.png Right-clicking the icon on the desktop and selecting "Properties" fails to open the file location. This needs to be fixed.
                            @monsterfox Will be fixed
                              @VectorStyler 9e074e6b-1603-4066-bc30-35938648ee89-6a740e6ee28a5e5a0aa4f4d00cbf8166.png
                              My software uses default font size parameters, yet parts of text are incomplete and invisible. This issue occurs on both panels and menus, hoping to get it fixed.
                                @monsterfox I will open a bug on this
                                  @VectorStyler https://www.youtube.com/watch?v=QYDHd0Qpy90
                                  I want to convert shapes to curves. The operation succeeds when there is no underlying image, but fails if an image is present at the bottom. Oddly enough, I didn't select the image at all. Please fix this issue.
                                  外观.vstyler
                                    @monsterfox For this you need to use Expand Stroke
                                      The default UI font should be Microsoft JhengHei UI when the Chinese language is selected.
                                        @VectorStyler Yeah, it's a font issue. I can't even remember when I changed the font.
                                          @VectorStyler https://youtu.be/FZuNl0duLVQ 外观-12.vstyler
