    Bug List for Version 1.3
    85 Posts 4 Posters 18.3k Views 4 Watching
      monsterfox @VectorStyler
      @VectorStyler https://youtu.be/Ax06GN5JwRg?feature=shared[0_1766927882644_合.vstyler](/forum/assets/uploads/files/1766927888679-合.vstyler)
      16.File Vulnerability Compilation & Fix Requests
      1. When multiple objects are selected and the Move Transform tool is used with the Transform Each option enabled, an error occurs: the sorting order of the graphics becomes chaotic instead of arranging from large to small.
      2. Text input is unavailable within the file.
      3. The Stroke Tool fails to work, and the corresponding stroke panel is also non-functional.
      4. There are numerous broken paths in the file. If all graphics are selected and the Join Overlapping Nodes function is applied, some graphics will be duplicated in their original positions.
      5. When two shapes are merged with overlapping areas, converting the merged shape to a rectangle will result in an unexpected positional offset of the generated rectangle.
      We sincerely hope these issues can be fixed in subsequent updates.
      VectorStylerV 3 Replies Last reply Reply Quote 1
        VectorStyler @monsterfox
        @monsterfox I added these to the backlog.
          The sorting order is the order of selection. In case of box selection, this is the stacking order of objects.
            The text in the file was converted to curves
              @VectorStyler 17,When selecting multiple objects by holding down the Shift key, clicking on an empty area will deselect all objects .
                I will fix this
                  @VectorStyler In 2025.12.11.23:33 the error of incorrect scaling when importing the two DXF files contained in the compressed package I provided into the program has not been fixed yet. It is hoped that this issue can be resolved.
                    @VectorStyler Fixed a bug in sizing imported SVGs(I tested those two files, and the error still exists. It still needs to be fixed.)If you import these two files into Illustrator and VS respectively, you'll see the difference. The size in AI is correct.
                      I tested with those two files, both in VectorStyler and Illustrator 2026 and the sizes are the same
                        Can you reupload these two SVG files, I'm not sure if I tested with the same.
                          @VectorStyler picture.dxf.zip Both files become smaller after import, so the size is not correct. Also, if you use the drag-and-drop method, one of the files cannot perform this operation. Please test it again.
                            @monsterfox Also send me a VectorStyler file with these files imported (I want to check the result of importing as it happens for you).
                              @monsterfox
                              These are the VS files I get with importing the DXF files:
                              22.vstyler
                              Picture.DXF.vstyler
                              In Adobe Illustrator 2026:
                              the "22.dxf" file imports and has the same size as in VS: width 223.8 pt, height 208 pt
                              Illustrator cannot import or open the "Picture.DXF.dxf" file
                                @VectorStyler https://www.youtube.com/watch?v=eBK79FwTJhQ
                                BUG.vstyler
                                  @monsterfox The VS document is in MM the Illustrator in PT
                                  78.96 mm is about 223.83 pt
                                    @VectorStyler No, both of my software are set to MM as the unit.
                                    https://youtu.be/QGbnutySYEo
                                      @monsterfox I will have to review the DXF format to see how the units are handled. I reopened this bug.
                                        @VectorStyler https://youtu.be/ZfK73KvZJkY
                                        The issue with importing DXF files has now been resolved. The only remaining problem is that when exporting to DXF, the size of the original geometry is incorrectly scaled up. This has been tested across multiple software versions, and the same result occurs every time.
                                          @monsterfox I will try to fix this
                                            @VectorStyler 2aa71e2f-fa48-41e3-9e2d-da9bed3cb17a-image.png Right-clicking the icon on the desktop and selecting "Properties" fails to open the file location. This needs to be fixed.
