Path Brush tool not leaving any results on screen
In the newest build (57), it appears the Path Brush tool is not working properly - it's not leaving any results on the screen. Is it working for anyone else?
@Boldline It is working here (just checked). What happens if you press Command+R (refresh)?
Is the path brush painting over an existing object, or is it a new paint?
@vectoradmin I tried the command-r refresh and then reopened everything.
I tried again without success. Maybe I am missing a setting?
I notice when I view the history panel on my left side, it does not register there when I go to leave a path brush tool mark. It registers when I swap the fill and stroke color, etc.
Works fine here, (win 10)
@Subpath That's good - maybe it's just me
What's odd here is that it's not registering anything in the history panel each time I lay down a brush mark.
@vectoradmin I did a reset using Shift + Option + Command and started VS and that solved the problem.
You had mentioned command-R to do the same as what Shift + Option + Command does? When I had tried command-R, nothing happened
@Boldline Command+R is just to refresh the document.
@Boldline This should be fixed in build 1.0.062
