Slider in Shape line tool (also in Shape panel) does not work
 I love the option in the shape line tools to set a number of lines or use spacing amounts! The slider to set the number of lines in the shape is broken - it only allows up to one line.... you can still enter the number of lines manually into the box
 The same issue occurs when trying to edit a line shape object slider line count with the shape panel
 @vectoradmin You may have already done this or thought of it - but I would think the the sliders should also be non-uniform. Probably a higher likelihood the user will want a number between 1-100 more than say, 500.
 @Boldline Most of the sliders now are nonuniform (those with long range).
 @Boldline This should be fixed in build 1.0.062
