    Screen not rendering consistently for some zoom levels
    10 Posts 4 Posters 10.1k Views
    • J Offline
      Jono
      I've observed under some conditions that stroke widths and certain text characters do not display correctly at all zoom magnifications. It is particularly evident when using a large canvas, for example A3, with fairly small objects or using a comparatively small font size. Screenshots below.
      Please let me know if you need further examples or more information.
        VectorStyler @Jono
        @Jono Can you send the file with these examples, to help replicate it. Thanks!
        • J Offline
          Jono
          Yep, file sent.
            I've also seen the missing pieces of text occur occasionally.
              Subpath
              Me too, very often when I enter new text.
              Zooming in and out then fixes the problem.
              Have also seen it with line width. Smaller objects
              e.g. circles tend to be drawn with a thinner line width.
              Seems only a Display Problem.
                VectorStyler @Jono
                @Jono I can replicate the stroke width issue, and this will be fixed for the next build.
                But so far I could not replicate the text rendering problem.
                If there are any suggestions on when this occurs, please let me know.
                • J Offline
                  Jono
                  Thanks looking into and fixing these things, it really is appreciated.
                  I've just spent a few minutes trying to establish a repeatable scenario without success. When it does occur it seems to only effect one character type.
                  In the following two screenshots it's the capital L in the first one, and in the second it's the lowercase s. I'll keep experimenting over the next few days.
                  • J Offline
                    Jono
                    Just confirming v1.0.054 has fixed the stroke width issue and seems to have fixed the text issue for me as well. Thanks.
                      VectorStyler @Jono
                      @Jono Thanks for letting me know!
                        Subpath
                        Same here, every thing seems fine, since Version 1.0.054
