Stroke Panel UI/UX Bug
First and foremost, the Cap and Arrow icons should be equal in size(make the Cap the same size as Arrow) the Arrow UP/DOWN from the left of Arrow should be present in CAP too. The presentation of the list of Arrow should be not a Drop Down list, but the same UP/DOWN list from the CAP list.
Now there is a bug where if I select the dropdown list for the Arrow Menu and click anywhere outside the list(but still in the Stroke Panel) the Stroke Panel gets dismissed, the same doesn't happen for the Cap List.
Can confirm that the bugs can be replicated.
This will be fixed.The type of list used for cap and arrow may stay different because typically we have large number of arrows but much less caps.
@vectoradmin Hmm you're right about the large number of arrows, but can you at least use the same style of translucent native macOS list? Btw just noticed that the BUG where if clicked anywhere else is present in all the dropdown menus not only in the Arrow List.
Thank you very much for your hard work!
This is fixed in build 146. A complete UI style review will be done before the final release.
@vectoradmin hey there this bug is still present
Yes, only the design was fixed here. the panel problems are still on
@vectoradmin aah okey okey, great job anyway, you're so FAST, fixing bugs
fixed in build 147
