Brushes missing
  • It may have been from me a while back, but I don't seem to have any of my per-installed brushes - either the ones you included or the set I add a few betas ago. I noticed they were missing when I upgraded to the first official mac release...
    @Boldline Is there a "brushtype.preset" preset file in the ~/Library/Application Support/NumericPath/vectorStyler1.0/vector/data/presets/ folder?
    If no then you should have the default brushes visible (those are in the app bundle).
    If yes, and then the brushes are from that file. What is the file size and date modified?
    There was no reset in the release, and since about six versions ago, the reset will not remove brushes.
  • I found the brush preset. I may have deleted them a while back in my experiments to switch away from the default brushes
    @Boldline BTW: it is possible to setup preset groups in user folders, and the turn on or off these groups in the Preset Manager.
    This way it is better known where the presets are stored.
