    Multiple occurrences of the same color are not included when creating a color palette.
    4 Posts 2 Posters 34 Views 2 Watching
    • S Online
      Subpath
      Duplicate or multiple occurrences of the same color are not
      included when creating a color palette from selected objects.
      I already mentioned this in another thread once.
      I mention it here again because it also plays a role in my
      gradient ideas and would be needed there as well.
      In my current experiments, identical colors are not added to the
      color palette in the order they appear on selected objects.
      Instead, each color is displayed only once.
      It's a bit strange, because I can definitely have multiple instances
      of a color within a color palette. Identical colors can also be copied
      from one color palette to another via drag and drop. So a color palette
      itself doesn't have any problems with duplicate colors.
      It would therefore be very helpful if the colors of selected objects
      could be copied simply from left to right into a color palette, even
      if the same colors are present multiple times.
      Here a pic with the selected Objects and the color palette result
      after choose "Create Palette from selected Objects"
      • S Subpath referenced this topic on
        VectorStyler @Subpath
        @Subpath Yes, this is by design.
        This can only be solved if I add an option
        • S Online
          Subpath @VectorStyler
          If this is possible, i would plaid for that option
          because it would make things a bit easier
          e.g. if you like to use a Palette for colorize
          • S Online
            Subpath @Subpath
            @vectorstyler
            A big thanks for include duplicate colors now
            when creating a color palette from a selection of shapes.
            Made a little Tutorial already
            https://www.vectorstyler.com/forum/topic/5731/a-color-palette-from-a-selection-of-shapes-takes-duplicate-colors-into-account-now.
