Recently used colors - Is there such thing?
Hi! Im wondering is there is some place where i can acces the recently used colors, as happens with fonts. Usually when you start to work with a document, you choose some colors and want to acces them easily instead of navigating a big color palette.
@marce
CorelDRAW has this feature, while in VectorStyler, you need to create a new color palette and add it manually. You can see the operation method here: https://vectorstyler.com/documentation/colors/palette/ -
@marce Color Panel has such a feature (should be on by default, panel menu Show Recent Colors)
@VectorStyler Great! I suggest it as default option. Thanks very much.
@VectorStyler said in Recently used colors - Is there such thing?:
I couldn't find it in the Color Palette Panel; it turns out it's in the Color Panel. The Color Panel offers more space, and it makes more sense to have it there. Thanks
