    How to switch to the transform tool easily, and go back to the current tool you are using?
    3 Posts 2 Posters 16 Views 2 Watching
    • M Offline
      marce
      Hi! Im testing VS, learning from it. When using a given tool, by example, the corner tool, is there a way to use some shortcut to temporarely go to the transform tool -for move or resize- and went back to the corner tool? I mean, if you press "Control", you can edit nodes, you release "control" and you are back to the corner tool. Is there some key shortcut you press and you go to the transform tool (move and resize are so offenly used)?
      Thanks any tip!
      Memory 48gb ddr4
      NVMe CT100p 1TB
        VectorStyler @marce
        @marce Each tool has an alternate tool (for the Corner tool it is the Node tool).
        Any other tool can be activated with its shortcut.
        For the Transform this is V. Pressing the shortcut again will return to the previous tool
        M 1 Reply Last reply Reply Quote 1
        • M Offline
          marce @VectorStyler
          "Pressing the shortcut again will return to the previous tool"
          That`s great and solve my question. Thanks
          Memory 48gb ddr4
          NVMe CT100p 1TB
