    update 1.3.007
    Scheduled Pinned Locked Moved Announcements and News
    5 Posts 4 Posters 357 Views 2 Watching
      VectorStyler 1.3.007 release notes
      • Improved SVG importing of graphics with scaled storke
      • Fixed a regression in changing selection
      • Fixed a bug in the Expanded Stroke effect
      • Fixed a layout issue with the Adjustment Layer effect view
      • Changing attributes in the Layers panel should not select the objects
      • Fixed a bug in color fonts handling
      • Fixed a bug in text underline handling
      • Fixed a bug in linked content importing form the Links panel
      • Eraser tool block mode to erase from any canvas shape if started with no selection
      • Fixed a repeater expansion bug
      • Fixed a bug with blends inside repeaters
      • Improved blending of mesh gradient
      • Fixed a bug in breaking blend objects at a position
      • Show all should set the correct visibility mode
      • Allow grouping single objects (used for effect stacking)
      • Fixed a bug in pasting shape for the concentric shape options
      • Improved path redrawing with the Pencil tool
      • Update measurement number variables inside text frames also
      • Fixed a bug in limiting image sizes in PDF export
      • Fixed a bug in importing outlined text from PDF
      • Fixed a bug in converting cloned objects to curves
      • Improved the text on path adjusting tool
      • Fixed a bug in refreshing shape paint objects when moving
      • Fixed a bug in simplify path with cusp nodes
      • Improved limit in the options of parabolic spirals
      • Fixed a bug in using the spell checker
      • Improved guideline selections sensitivity
      • Fixed a bug in snapping
      • Fixed a bug in printing guidelines or girds
      BoldlineB 1 Reply Last reply Reply Quote 9
      • E Offline
        EricP
        @VectorStyler thank you
        • W Online
          William Kansepa
          This is wonderful!!! Thank you @VectorStyler .
          • W Online
            William Kansepa
            Single object grouping OMG!
            Splendid!
              @VectorStyler said in update 1.3.007:
              Thank you for the long list of bug fixes and improvements. The guideline selection is fixed and working so much better!
