    Intertwine Feature and a way to fake gaps
    7 Posts 2 Posters 979 Views 2 Watching
      Subpath
      Part one (this Post here)
      Part two (some finds)
      https://www.vectorstyler.com/forum/topic/5572/intertwine-feature-and-a-way-to-fake-gaps/3
      Intertwine is a new feature in VS since version 1.3.
      Which work only with at least two separat Objects.
      Unlike the "Crossing Gap" shape effect, which only works
      with a single path, the "Intertwine" effect doesn't offer
      gap settings. At least, none that I'm aware of. However,
      these can be faked. In this thread, I'll show way how.
      Some preservation
      We first need at least two objects. Lets choose the also new
      Polygonal Loop object for them. To better distinguish them,
      I'll color one blue and one red. Of course, both could also
      have the same color.
      Now, we need to use a suitable line weight. Take a slightly
      thicker line weight. You'll see why in a moment. I keep the
      originals by creating a copy of both objects in case I change
      my mind about some design decisions.
      Expand the outline, this results in two shape objects. Add a outline to
      both in the color of the background. In our case, the color white.
      Intertwine them
      You have two possible ways to do this.
      Both ways require to select your objects first.
      First way
      Use Menu > Styles > Intertwine > Create Intertwine Group
      and then select the Intertwine Tool to place your Intertwines.
      Second way
      Use the Intertwine Tool directly. Select the Intertwine Tool, click onto the
      Objects a Dialog appears "Create Intertwine Group" confirm this and you
      can continue to place your Intertwines.
      Placing the Intertwines
      One click with the Intertwine tool place the Intertwine.
      Another click toggles between the two possible states.
      In our example, either part of the blue object or part
      of the red object is raised. To confirm a state click
      once elsewhere.
      As you can see, both the shape and the outline are raised.
      Since the outline color and the background color are identical,
      it looks like gaps.
      Those are the basics. But with the Intertwine tool
      and some other features of VS, I can tell you that
      there's a lot to discover. 🙂
      I post a few things i found in a later post.
      Will take some time.
      Of course everyone is welcome to post here too
      if they have found something nice.
      Have fun being creative.
      1 Reply Last reply Reply Quote 8
      • E Offline
        EricP
        @Subpath thanks for this nice tutorial. Will try it when I find the time
          Subpath
          As i wrote there a some possibilities to discover.
          Here some finds
          Let start
          A simple rectangle
          round the corners a bit
          create a simple blend with it
          a easy way to give it a more sophisticated look
          is using Stripes
          its no problem using stripes with
          the intertwine tool
          by using the same way i descripted above
          to fake gaps you get this
          here a result of mine
          you need to be a bit tricky to get the that gradient
          from Object to Object
          Create a gradient > Rasterize the Object (convert it into an image)
          and do a "Intersect" Boolean on all objects with the desired
          spacing between them.
          arrange them back then and do the "Intertwine"
            Subpath
            Easy way to create a pattern for use with the Intertwine tool
            One feature in "VS" that allows you to create patterns for the Intertwine Tool
            is the "Outline ZigZag" Shape Effect. Especially the "Wave" Mode of this effect.
            This Shape Effect can be applied to many shapes, I recommend to use round
            or rounded shapes with it.
            Here the basic steps for that way.
            Lets create a simple Line.
            Then apply the "Outline ZigZag" shape effect to it.
            Set Mode to “Wave”. Width to 45 and spacing to 75.
            You find that Shape Effect here:
            Effects > Outline > Outline ZigZag
            Create a copy of this object, select it, switch to the Node Tool and select
            "Reverse the direction of the selected Path" in the contex panel. This
            changes the path direction and effectively reversing the shape effect.
            Now select both objects and center them and you have the basic Pattern.
            You could also apply a Profil to the Stroke
            before using the Intertwine Tool of course.
              Subpath
              The Profil Setting in the "Outline Zigzag" Shape Effect
              If you notice that the "Outline Zigzag" Shape Effect has a setting
              called "Profile", you might be confused, as I was at first glance.
              However, instead of changing the stroke thickness, the Profile setting
              for the "Outline Zigzag" Shape Effect affects the wave pattern. You
              can use it to define the length of the wave pattern and fade the effect
              in and out.
              This setting is another interesting way to further customize the pattern
              described above. But the "Standard" Stroke Profil option is still useful.
              Here some examples
              Create your own Profil works the same as with Stroke Profil
              Using the “Shape Effect” Picker Tool its a very easy way to transfer the
              "Outline ZigZag" shape Effect to different Shapes.
              Select your shape then the Shape Effect picker and choose the Shape
              where to pick the Shape effect from.
              Thats all. Have a nice day and fun being creative.
              • E Offline
                EricP
                @Subpath said in Intertwine Feature and a way to fake gaps:
                called "Profile"
                I did not, but now I like it. Thanks for highlighting it
                  Subpath @EricP
                  @EricP
                  I didn't notice it at first either.
                  The crazy thing was.
                  I was looking a long time for something like this
                  and tried some crazy workarounds to get something similar.
                  Then I tried this profile setting and realized
                  it was exactly what I was looking for ... ☺
