update 1.3.004
VectorStyler 1.3.004 release notes
- Improved performance of text frame handling
- Improved drop shadow editor
- Allow drop shadow inside intertwine groups
- Allow repeater and halftone preset selection from the presets panel
- Transform each mode in Move to incrementally move objects
- Added preview option to the Transform Object view
- Improved BMP file support
- Improved precision in shape merging
- Do not sort Recent Fonts list by default
- Create group of single object when creating mirrors
- Fixed a bug in RTF importing (text encoding)
- Fixed a regression in iconified panels
- Fixed a bug in removing stroke inside intertwine groups
- Fixed a bug in SVG importing with masked images
- Fixed a bug in Text Wrap view Preview mode
- Fixed a bug in creating blend effects inside moved layers
- Fixed a bug in Font list and panel search clearing
- Fixed a bug in the curvature tool when used to extend shapes
- Fixed a bug in brush width indicator while using the brush tool
... Create group of single object when creating mirrors ...
test it already, works great
@VectorStyler About the RTF import, there are some issues still. Look this: in MSWord, it is displayed as following:
And an accented word in this way:
But when imported in VS, in the first case, space is not presents between normal and bold text:
And in the case of the accented word, an space is inserted:
Im attaching the rtf file, that is copy&paste from wikipedia:
https://drive.google.com/file/d/1b6pStv6W5hJbWq6KpQyVpHSYthfuKVmM/view?usp=sharing
@VectorStyler About Text frame, im not sure if it is related to text frame. When i move a text frame in a single artboard, i have a no lag movement. When doing that with a multiple linked text frames across boards, i have a little lag.
Additionaly, when i insert an image when there is a multiple artboards, with linked text frame, i have no lag moving the image. But, after i acivate wrap, i have lag. If i deactivate lag, the lag persist, it dont roll back to the non lag movement.
Can be seen here:
https://drive.google.com/file/d/10Of-WmgcRPe9c_zLex2JcQ7GklVnLC68/view?usp=sharing0_1766085114755_Probando multiple artboards.vstyler
Im attaching the file with multiple text frames that dont have the same performance than a single artboard.
Im not sure if im explaining this correctly that can be understood.
and the crashy bmp are imported correctly! thanks very much
@VectorStyler Recent fonts ordered from last used and so on. Great, thanks!
@marce text wrap can cause the same lag as resizing a text frame.
There was a regression in the new build when using shortcuts with Command+, a fix was uploaded.
This requires a manual download and install of VS (no version increment).
@VectorStyler Thank you for fixing it so quickly!
