    Properties Panel stroke settings not updating in brush
    2 Posts 2 Posters 3.3k Views
      In the newest VS released today - when I go to change the stroke width in the properties panel, it will not permanently change unless I manually type it in. If I adjust the size any other way, it reverts back to whatever initial setting was there. If I do any method of changing the size of the stroke in the stroke panel - it works just fine.
      I understand I could always just do it in the stroke panel - but the properties panel is what pops up automatically when I use the brush tool - plus if it shows itself in that panel, it should function.
      here is a video showing that
      UPDATE: Running into some issues with the stroke panel. If I start from "0.0" and change the size of the brush, it reverts back to zero when I use it. As long as the number is something to start with, I can edit it just fine after.
      Here is a video of that
        @Boldline Can be replicated, added these to the backlog.
