    Repeater option to edit shape directly with existing repeater preset
    5 Posts 2 Posters 766 Views 1 Watching
      I seem to remember in older builds pre 1.3, that I could create a shape and give it a gradient fill and then apply a repeater preset to it and get an instant repeater result like a halftone, for example. The gradient would act as the intensity map that drives size and color.
      now it seems that is not possible anymore - was this moved to the halftone tool? I tested it there and that works.
      The real use case would be creating a series of gradients in different shapes and then selecting them and converting them to a halftone repeater pattern
        @Boldline said in Repeater option to edit shape directly with existing repeater preset:
        Should be possible, if not, it is a bug. I will test this
          Update: I switched over to the default settings and repeater worked correctly with this task. I switched back to my custom settings file and repeater is also now working properly… I’m not sure what happened but it’s working now.
            @Boldline There was a fix in 1.3.003 in selecting repeater presets from the panel
              @VectorStyler oh great! Thank you for fixing that
