    DXF Versions
    3 Posts 2 Posters 423 Views 2 Watching
    • J Offline
      JET_VS
      Is VectorStyler supposed to be able to open DXF R12 files? The Help documentation does not list any DXF formats, but it seems to be able to open DXF R14.
      JET
        VectorStyler @JET_VS
        @JET_VS Older DXF files are not fully supported, both for DWG and DXF the support is mainly after R2000 (import and export), with some support for importing earlier versions.
        If you have some older DXF files that do not import, please send it by email and I will try to improve DXF support.
        • J Offline
          JET_VS @VectorStyler
          @VectorStyler Thanks for the quick reply.
          If you have some older DXF files that do not import, please send…
          Thanks, but I'm not really needing that. I'm just making some examples to demonstrate the decades-old "polyline" problem of the CAD>DXF>Bezier workflow (which I don't recommend, if at all avoidable).
          So I just wanted to make sure not being able to open the R12 files I'm using to demonstrate, is not unique to my installation. I can open R14 versions of the same files, (which do not demonstrate the polylines issue, but break curves at every path segment).
          JET
