    Add sub-categories to the repeater presets menu area?
    12 Posts 2 Posters 1.8k Views 1 Watching
      Could we add sub-categories options to the repeater presets section? I would like to add other halftone and line and tirangle shape options for quick use but I can see the menu getting very long and cluttered without some way to better organize them
      0_1764954655051_a5acc1c4-948c-4015-a261-b89b3418f46c-CleanShot 2025-12-05 at 12.07.54.png
        @Boldline In the Preset Manager it should be possible to organize presets into folders.
          @VectorStyler said in Add sub-categories to the repeater presets menu area?:
          I understand that there is a universal presets panel with access to all the presets available on a program level.
          I'm not seeing where the repeater presets are being saved, neither the default halftone and stippling options or the new one I called "triangle and had saved into the preset folder earlier today.
          0_1764984953581_f16a3b9c-5d17-4bc1-a49a-fce6419a8b82-CleanShot 2025-12-05 at 20.33.45.png
          0_1764984987806_978750d4-55f4-4b31-9eb3-a883573ffe32-CleanShot 2025-12-05 at 20.36.17.png
          0_1764985098337_9e90be94-f1bb-47e9-910b-eab974af1f75-CleanShot 2025-12-05 at 20.37.52.png
          I saved my custom preset to the "Presets" folder and it shows up when I go to use a repeater preset:
          0_1764985180714_4d72cb73-bd3e-4914-abf3-a7448f1133af-CleanShot 2025-12-05 at 20.38.42.png
          The problem is, I cannot find the them anywhere (they are not visible in the main preset panel), I don't have a way to delete one and there is no link option from the repeater extended menu to open a custom preset folder much less an option to save custom presets to that custom folder.
          I'm thinking of it much like how we can open a custom color palette
          0_1764985532756_6005920b-5276-45d7-972d-e90a20e9ec1d-CleanShot 2025-12-05 at 20.41.25.png
          0_1764985568253_8d4d2381-e6a6-4c89-b2b2-c3aed4c10c09-CleanShot 2025-12-05 at 20.45.45.png
          Hopefully I am making sense as to where the issues I am having are.
            @Boldline This might be a bug (not listing all preset types). I will solve this.
              @VectorStyler ok sounds good. Does it make sense to have a an option to save presets to a custom folder? And then have access to that folder from inside the repeater panel menu?
              I may need to read up more about the presets but I was also thinking of ways to be able to share a repeater preset batch easily between user computers and others.
                @Boldline said in Add sub-categories to the repeater presets menu area?:
                This would require a bit more selection options in the preset saving UI. For now, I the Preset Manager will be the place to organize things into folders.
                  @VectorStyler ok. if I want to move saved presets to a different computer - could we add an option to do that? Either an option to go to the preset folder to select and copy and paste or an option to export a preset?
                    The Preset Manager should be able to export presets, and to create preset groups saved into a user selected folder.
                      @VectorStyler If I want to save out a preset from the preset manager, would that mean using "save as" or "save selected" and then choose a new location to collect the presets to copy to another computer? I was not seeing a dedicated export option like "export selected", etc.
                      0_1765126003793_3cd56ebe-87ee-4c93-9ebb-fa42d32caa31-CleanShot 2025-12-07 at 11.46.12.png
                      I was also thinking about digging in to the presets folder itself to find the presets to copy and paste, but from what I found, it does not seem to show all of them. Maybe I'm not looking in the right place?
                      0_1765130833028_7b8ff751-6708-4267-ac85-81c9706ef73e-CleanShot 2025-12-07 at 11.49.23.png
                      0_1765131047302_1729e9ac-c646-4aec-ad8a-0be0655a6f15-CleanShot 2025-12-07 at 13.10.21.png
                        @Boldline "Save Selected", but first select the presets.
                        Use the "Reveal Workspace Folder", go up one level and you will find a presets folder
                          When I go up a level and into the presets folder, I see one repeater preset listed. I don't see the default repeater presets that come with VS or the several custom presets I already created.
                          0_1765647203322_e1e0a0e6-591a-496b-9889-2473a69711c4-CleanShot 2025-12-13 at 12.33.03.png
                          When I look in the Window>Presets Flyout menu, I see dedicated options for brush presets, document presets, an option to open a brush preset file. I was confused why the brush presets options are listed but not the other presets, but I assume that's because users are most commonly importing brush presets?
                          When I go to the presets panel, repeater brushes are not listed at all. You mentioned it might be a bug, but I have an old windows laptop I had yet to upgrade to VS1.3, so it was still using VS1.2. On that laptop, the same presets panel also lacks a repeater preset folder
                          0_1765647413144_50b972e9-0721-4663-aa7a-0ab77c52df6b-CleanShot 2025-12-13 at 12.36.42.png
                          0_1765647394909_027277e3-5eb9-49d2-ab06-7e1b5a701178-CleanShot 2025-12-13 at 12.35.28.png
                            That file contains all the current repeater presets. The default presets file is in the VectorStyler bundle (similar location), but it was copied to this file.
                            Brush presets have a separate menu command because it is quite common to use these and there are typically many of them.
                            Other presets could have a separate panel, but then it gets too crowded with menu commands.
                            You can drag out a section from the Presets panel into a separate panel.
                            I will fix this
