    I would find it useful if one could save presets for the mirror feature.
    10 Posts 4 Posters 1.9k Views 3 Watching
      Subpath
      I assume there are plenty of uses for the new Mirror feature.
      To avoid having to manually adjust frequently used degree settings
      every time, I think it would be nice if you could save presets.
      At first, I only thought of different degree settings like 30°, 45°, 60°, etc.,
      but it certainly makes sense to be able to save other parameters as well.
        VectorStyler @Subpath
        @Subpath Yes, probably the same for the Transform Objects and Align Objects on Path also.
        • E Offline
          EricP
          @VectorStyler yes, Transform object presets would be great (+preview)
            I had also been thinking about this yesterday as I was creating a four leaf clover - wanting to figure out a way to get four quadrants to create and then edit the four parts in real time. Also similarly with a shamrock, an option to set the number of "quadrants" to 3 or any other number and then adjust the angle.
            Hopefully this is relevant, but the attempts I was making using the mirror tool yesterday and @Subpath's post here made me think of the settings in Procreate in setting up mirroring. It's fairly basic but it offers quick guides to the most common mirroring
            0_1764170803227_27928c58-e59a-4097-b55d-a8fc06535a6a-CleanShot 2025-11-26 at 10.26.25.png
            0_1764170843867_4733a3b7-3bf3-4994-9e4c-023e099036dd-CleanShot 2025-11-26 at 10.27.07.png
            0_1764170870934_afcf492e-85b6-4774-b963-1c18e8d8cf64-CleanShot 2025-11-26 at 10.27.32.png
              Subpath @Boldline
              @Boldline
              I also missed some guidelines, or at least
              markings that indicate where the center point is.
                @Subpath said in I would find it useful if one could save presets for the mirror feature.:
                Should there be an axis indicator preview of mirror groups, even when the mirror tool is not active ?
                S 2 Replies Last reply Reply Quote 0
                  Subpath @VectorStyler
                  I will answer later today and post a few Pictures then
                  how other Software solved this.
                    @VectorStyler said in I would find it useful if one could save presets for the mirror feature.:
                    In my opinion, this is not necessary.
                    Made a Video here, how CorelDraw 2020 handle symmetry
                    and how Black Ink (Bitmap app) handle it for inspiration purpose.
                    Here the Link
                      Boldline @Subpath
                      @Subpath Thank you for the video showing how other apps do it. I like how corel offers the small panel where the number of quadrants can be edited easily. Correct me if I'm wrong, but it seemed there was no way to move the entire mirror effect to a new location on the artboard without it affecting the placement of the objects in the process.
                        Subpath @Boldline
                        @Boldline
                        i correct you 🙂
                        Its no Problem to move, lets say the group of mirrored Objects.
                        Just push the finish Button and you could move the whole group.
                        If you in Mirror Mode only the original Object is movable or the mirror guides.
                        Here a Video to show it.
