    update 1.2.090
    Scheduled Pinned Locked Moved Announcements and News
    3 Posts 2 Posters 790 Views 2 Watching
      VectorStyler 1.2.090 release notes
      • Fixed a clipping issue when exporting images to PDF
      • Fixed a bug in selecting corners with the corner tool
      • Fixed a bug in using reduced image resolution when exporting to PDF
      • Convert to curves before breaking apart to keep stroke transform
      • Convert to artboard should keep the object
      • Shaped layers should move with artboards
      • Fixed a bug in changing page format options for a single page
      • Fixed a bug in repeater colorizer preview
      • Fixed a bug in the Coverage intersection mode
      • Fixed a bug in the solid stroke and remove stroke buttons in popover
      • Opening path eraser tool with no selection should erase on canvas
      • Flattening opacities should use document color mode
      • Allow using grouped text on path as displacement effect mask
      • Improved scrolling in the object roles list
      1 Reply Last reply Reply Quote 8
      • A Offline
        ai_slop
        Were there any changes in the display rendering in 1.2.090? I thought 1.2.088 was smoother when moving nodes. I see a slight jitter or flicker but maybe it's my machine.
          VectorStyler @ai_slop
          @ai_slop No changes in rendering. You can try reinstalling the previous build to compare the rendering.
