Addional Alignment Option, align Objects with one click horizontal and vertical
I don't think any user here can count how many times they've
clicked these two icons to center objects horizontally and
vertically.
Maybe I'm just lazy?But I would plaid for an additional alignment option that
combines these two icons into one. And I would only have to
click once to center align objects horizontally and vertically.I'm also surprised this was never considered.
@Subpath Actually, it's quite simple. My workflow is to set up an action: select the objects that need alignment, press the vertical alignment once, then press the horizontal alignment, and finally assign a shortcut key to this specific action to get it done.
What I set up is the F5 key
Indeed it's actually easy and possible
And I think I'll use that approach.But I wonder why combining these two alignment options
was never considered.@VectorStyler, forget my request. I'll use an action like
Monsterfox suggested.
@Subpath But which combinations are to be added? Out of the 9.
As I already wrote, just ignore my request.
I'll create an action, just like Monsterfox suggested.I dont know if my idea was so well thought. Because a ninth
Alignment Icon would create a mess in the Alignment panel.But my idea was to combine these two in a addional icon.
Currently, two clicks are always required to center objects
horizontally and vertically, something that would normally
require just one click and is used very often.But forget it. I'll use an action, and that'll be fine for me.
