UI language translations (BETA)
Hello,
A (beta) UI language translation is available now in the current build, for testing, but it has to be enabled in the license server for individual licenses.
Please post here if you are interested to try in any of these languages and have a license (and willing to put up with mistakes
The following languages are available:
EDIT: since this is just a closed beta for now, the language selection is enabled per license.
So once this is enabled for a license on the server, VS needs to be restarted and then the settings is enabled.
@VectorStyler if I can be of any help, I'd be happy to try out the French translation of VS... however, I don't have too much time at the moment (could not give feedback rapidly)
@B-Vs-V In Settings -> Application first row, should be enabled once requested.
@VectorStyler Ok, it is fine
I want to test Chinese version
@roychen Restart VS and the Settings -> Application -> Language (beta) should be enabled for you.
The Chinese beta version has finally arrived, and I have been waiting for it. Please provide me with the Chinese version for testing. Thank you
@VectorStyler I can spare some time to test it.
I can help on French version
@VectorStyler An obvious issue with the Chinese interface is that the text is not fully displayed, especially on the panels. I have tried different settings and even set the system display to 100%, but the problem persists. I will review everything and point out the problematic areas.
Properties Panel
@Li-Xiao Got it, this seems to UI font issue on Windows. I will try to fix it for the next build.
@VectorStyler Suggest changing '普通话' to '简体中文'
@Li-Xiao said in UI language translations (BETA):
Wil do so. There is also a UI font issue on Windows.
@Li-Xiao The new build contains some improvements for the translations also.
The Chinese language display should be fixed, but it might depend on the selected UI font if that was customized.
The Chinese interface is displaying correctly over 95% now. However, 'Simplified Chinese' has become 'Traditional Chinese'. There are still some minor issues with a few panels.In version 1.2.073, the Chinese UI is Simplified Chinese (简体中文), while in version 1.2.074, the Chinese UI is Traditional Chinese(繁體中文). It's best to keep both, as Mainland China uses Simplified Chinese, while Hong Kong, Taiwan, and Macau use Traditional Chinese.
Most software with Chinese interfaces provide both Simplified Chinese and Traditional Chinese options, such as Adobe and Corel....
I will include both in the next build.
@VectorStyler The presets in the Mask options of the Transparency panel, Properties panel, and Image Effects panel are not translated.
@Li-Xiao Yes, most of these "extra" preset names are fixed (not part of translation).
I will try to add these to the translated text also.
@VectorStyler In general some things that are not translated can be: preset names, recorded or recent action names, and various names (like canvas, or layer) saved into documents.
Two types of Chinese can be consistent like the two types of Portuguese.
中文(简体)
中文(繁體)
