File currently being used
 The currently used or opened file can be deleted and replaced. This logic is not ideal and should be fixed.
 @monsterfox Actually, the replacing of an opened file is a feature. One can change the file form some other tool and if the file was not modified in VS, it will be automatically updated when VS gets to foreground.
 (BTW: you can save a VS file into JSON or XML format, and edit it with a text editor , and if the file is open in VS it is automatically updated ) , and if the file is open in VS it is automatically updated )I will have to check the delete part.
