    How to snap handle to the tangent line?
    12 Posts 5 Posters 8.4k Views 5 Watching
    • AyoA Offline
      Ayo
      How to set snapping settings or is there a modifier to make point handle 'h1' snap to the tangent line of straight line segment 'p1' to 'p2'?
      • Devil DinosaurD Online
        Devil Dinosaur
        You can press ctrl+click (Mac) on the handle and set it to "symmetric" or press "y" while the handle is selected.
        Fred.
        AyoA 1 Reply Last reply Reply Quote 1
        • AyoA Offline
          Ayo @Devil Dinosaur
          @Devil-Dinosaur
          Thanks but that makes p2 a smooth point with two new handles between p1 and p2. It does not make point handle 'h1' snap to the tangent line.
          VectorStylerV debraspicherD 2 Replies Last reply Reply Quote 2
            VectorStyler @Ayo
            @Ayo said in How to snap handle to the tangent line?:
            No such feature.
            A workaround is to use the path panel: select the p2 node and (depending on the path direction) set the tangent angle to the other angle +180.
            AyoA 1 Reply Last reply Reply Quote 0
            • AyoA Offline
              Ayo @VectorStyler
              Cumbersome.
              Maybe an idea for the future to add a tangent point to the cusp and smooth point series? Like Freehand/Fontographer has?
              0_1741685247402_8c49bfdb-8ef3-4a52-87d5-f91e4f39ee40-image.png 0_1741685288754_c29f219a-ead4-412b-9d93-cb507f406631-image.png
              • debraspicherD Offline
                debraspicher
                I would use this quite a bit if a shortcut/snapping option existed.
                32GB RAM @ 6000MHz
                PNY NVIDIA RTX 5070 Ti 16GB; Display 1: 4K @150%; Display 2: 4K @150%
                  debraspicher @Ayo
                  @Ayo I have done Devil's method by sometimes selecting the P1<->P2 line segment and right clicking "Line" or pressing 1. Then if I convert P2, sometimes I can get a nice transition.. but it's never exact as you say.
                  32GB RAM @ 6000MHz
                    VectorStyler @debraspicher
                    @debraspicher @Ayo Not sure I can do this before 1.3, but for 1.3 it might be possible as an action from the Path panel.
                    debraspicherD 1 Reply Last reply Reply Quote 2
                      Subpath
                      For those who may not know, in some cases it's possible to align handles
                      using the alignment panel. (Horizontal, Vertical)
                      Here's a video
                      AyoA 1 Reply Last reply Reply Quote 2
                      • AyoA Offline
                        Ayo @Subpath
                        @Subpath said in How to snap handle to the tangent line?:
                        For horizontal and vertical angles (0 and 90 degrees) the existing snapping option is sufficient. It is precisely when the segment p1_p2 has an unusual angle that the problem occurs.
                        • AyoA Offline
                          Ayo @Ayo
                          @Ayo
                          FYI
                          Astutegraphics PathScribe
                          When dragging the handle it snaps and gives a small red "c" (connector point) indicating when aligned precisely.
                          After released, dragging the handle keeps the constrain angle.
                          Freehand
                          Freehand needs a connector point for this. Also here, after assigned point to "Connector Point", dragging the handle keeps the constrain angle.
                            debraspicher @VectorStyler
                            @VectorStyler Thank you. It's an important function for things like lettering/logotype. An easy example, if someone is designing a custom typeface that's based on a skew, having a snapping feature would speed things up for getting those clean curves...
                            32GB RAM @ 6000MHz
