Memory loss
I remember a setting something like 'Max number node/point preview'. But I really can't find it anymore. Can someone show me the way?
@Ayo Is this for the Node editor? I think there is no settings for this.
No. Selection preview -
@Ayo said in Memory loss:
Selection preview
Could be in Settings -> Constraint -> Show Transform Outline
Thanks, that was it! I didn't expect it under the heading Constrain.
But anyway, doesn't solve it.I have a map test export SVG fom QGIS with export option layers to groups on.
Opened it in VS, did group to layers.
My land layer gives vertices preview when hovering or selecting with selection tool. Exept France and Norway. I thought why? Maybe that setting...
Secondly, one more question; the above action splits the land layer polygons into a separation of fill and stroke objects. Not polygon with stroke property as a whole. Is that intended? -
Yes, it is how the SVG import works. I will try to improve this.
FYI: ai returns polygon with stroke propertyCould there be another reason for problem 1?
I need a file to see what can cause this (send me by email).
Sent. Layer 5, France and Norway -
@Ayo Yes, the cause is the number of nodes (not available as a setting). I will try to find some solution to show some nodes even for these cases.
