    Missing custom style in halftone within the image effects
    21 Posts 4 Posters 30.6k Views 4 Watching
    • L Online
      Li Xiao
      The halftone in the image effects offers many options, but lacks a custom style for pattern fills, textures, Multiple texts, and arbitrary shapes.
      Reference image:
      https://www.deviantart.com/limeform/art/C8MrJpuwjDM-ad21-amd30-r22-ii3-composite-985211208
      https://www.deviantart.com/limeform/art/Grass-ad20-ard2-aro0-amd50-r21-983981540
      https://www.deviantart.com/limeform/art/Matching-r21-tad20-981956443
      Refer to an Adobe Illustrator plugin:
      https://go.screenpal.com/watch/cZhI2EVL6De
        VectorStyler @Li Xiao
        @Li-Xiao This goes to the features backlog. I will try to implement it in the repeater, as this looks like it should be a vector feature.
        L M 2 Replies Last reply Reply Quote 1
        • L Online
          Li Xiao @VectorStyler
          @VectorStyler It would be fantastic to have support for it in Repeater. However, when there are too many objects, the computational speed might be slower compared to using the Halftone effect on images. The Halftone effect on images also offers some options that are not available in Repeater, such as image channels.
            @Li-Xiao said in Missing custom style in halftone within the image effects:
            The problem is that Halftones are calculated when rendering the final on screen image. The repeaters are calculated once when the repeater object is changed, and they stay the same vectors when rendering.
            So this might be faster with repeaters.
            • L Online
              Thank you for the explanation.
              Are several filters of Artistic Halftone (https://pixeology.com/ArtisticHalftone/features.html) suitable for Repeater?
                @Li-Xiao Stippling and Anyscreen could be suitable. but Stochastic Screening and Texture Halftone are not. But for these there might be extensions to the repeater or some other (new) vector feature.
                • L Online
                  I'm really looking forward to it.
                  Is this mycelium effect suitable for Repeater?
                  https://onecm.com/v4/mycelium.html
                    Not really. Here it looks like there are some random curves, with density adjusted to image tone.
                    I think these kind of effects will be specialized plugins later.
                    • M Offline
                      monsterfox @VectorStyler
                      @VectorStyler This is just a case, I know that VS can also do it. I want to ask, can this function be added in the repeater? Make it into a switch to fuse two adjacent shapes. Make a halftone effect. https://www.youtube.com/shorts/Au79csRg6QY?feature=share
                      VectorStylerV S 2 Replies Last reply Reply Quote 0
                        VectorStyler @monsterfox
                        @monsterfox In the video, some of the shapes are handled differently than others, so this is not for the repeater.
                        But otherwise, yes this is doable in VS.
                          Subpath @monsterfox
                          @monsterfox
                          take a look at this video from @encart to get the Idea
                          Note: Hold the Alt-Key and do the Boolean Union then
                          (this is Vectorstylers Combine Mode (Live BoooleanMode))
                          Here the Video
                          He post this in a Tutorial of mine which shows some
                          possibilities of the Combine Mode
                          https://www.vectorstyler.com/forum/topic/1963/easily-editable-arrow
                          • M Offline
                            @VectorStyler Okay, I just want to figure out how the fusion effect of adjacent graphics in the halftone effect is achieved, and it feels similar to the effect in the video, so I put forward a suggestion.
                            • M Offline
                              monsterfox @Subpath
                              @Subpath Thank you for the tutorial link. I will try the halftone effect and see if the graphic fusion works.
                                @monsterfox Similar steps as in the video, but you have to expand the repeater.
                                • M Offline
                                  monsterfox @Subpath
                                  @Subpath The effect is not the same as I imagined. 0_1717947713567_mmexport1717947698681.jpg
                                    Subpath
                                    @monsterfox
                                    I don't know what you had in mind,
                                    and I'm not sure if what was shown in the video
                                    is possible with the repeater
                                    In the meantime i figure out that the Affinity Designer
                                    Contour Tool works a bit different then the VectorStyler
                                    Contour Tool.
                                    Affinity Designer allows no Color in their Contour Tool
                                    which VectorStyler Contour Tool does not offer.
                                    To get the Effect shown in the Video in VS your Circle has
                                    to have a Stroke and "Use round joins on cusp corners" set.
                                    Here a video showing the principle in VS.
                                    It also takes a bit more work to do this with the Contour tool
                                    in VectorStyler than manually. But on the other hand, the
                                    Contour Tool produces interesting results.
                                      Subpath
                                      @monsterfox
                                      I gave the Repeater a go
                                      Repeate Circles with a Contour and
                                      "Use round joins on cusp corners" set like this
                                      Reduce the Space between them (in Repeater)
                                      to get the Effect
                                      Expand the Result from Repeater and
                                      delete the Circles you dont want to process.
                                      Select the circles and do a Boolean Add.
                                      • M Offline
                                        monsterfox @Subpath
                                        @Subpath Really thank you for your enthusiasm. I have mastered the effect in your video. The effect I imagined should be like the bitmap in Photoshop, the halftone effect, and the circle graphics above 50 degrees of gray will fuse until 100 degrees of black.Their fused state is based on the current graphic, but my effect picture is not the same. The fused area is in a plum blossom state.
                                          Subpath @monsterfox
                                          @monsterfox
                                          Thank you, I don't see that as enthusiasm. When I saw your video,
                                          I remembered that Encart had already shown something similar.
                                          As far as I know, this fusion effect only works well with shapes of the
                                          same size. So I don't know how your idea could work.
                                          • L Online
                                            Li Xiao @Subpath
                                            @Subpath
                                            He wants to create Euclidean halftone using the Fusion Ball method. Currently, Repeater and Fusion Ball cannot achieve this. We are looking forward to version 1.3 to see if it can be done.
                                            Euclidean dot (Transforming Round Dot): Round/Square/Round
                                            https://workflowhelp.kodak.com/download/attachments/229783381/worddava24f2bf877b5355acdd16d960264293a.png?version=1&modificationDate=1686070462915&api=v2
