    Missing custom style in halftone within the image effects
    21 Posts 4 Posters 30.6k Views 4 Watching
    • L Offline
      Li Xiao @VectorStyler
      @VectorStyler It would be fantastic to have support for it in Repeater. However, when there are too many objects, the computational speed might be slower compared to using the Halftone effect on images. The Halftone effect on images also offers some options that are not available in Repeater, such as image channels.
        VectorStyler @Li Xiao
        @Li-Xiao said in Missing custom style in halftone within the image effects:
        The problem is that Halftones are calculated when rendering the final on screen image. The repeaters are calculated once when the repeater object is changed, and they stay the same vectors when rendering.
        So this might be faster with repeaters.
        • L Offline
          Thank you for the explanation.
          Are several filters of Artistic Halftone (https://pixeology.com/ArtisticHalftone/features.html) suitable for Repeater?
            @Li-Xiao Stippling and Anyscreen could be suitable. but Stochastic Screening and Texture Halftone are not. But for these there might be extensions to the repeater or some other (new) vector feature.
            • L Offline
              I'm really looking forward to it.
              Is this mycelium effect suitable for Repeater?
              https://onecm.com/v4/mycelium.html
                Not really. Here it looks like there are some random curves, with density adjusted to image tone.
                I think these kind of effects will be specialized plugins later.
                • M Online
                  monsterfox @VectorStyler
                  @VectorStyler This is just a case, I know that VS can also do it. I want to ask, can this function be added in the repeater? Make it into a switch to fuse two adjacent shapes. Make a halftone effect. https://www.youtube.com/shorts/Au79csRg6QY?feature=share
                    VectorStyler @monsterfox
                    @monsterfox In the video, some of the shapes are handled differently than others, so this is not for the repeater.
                    But otherwise, yes this is doable in VS.
                      Subpath @monsterfox
                      @monsterfox
                      take a look at this video from @encart to get the Idea
                      Note: Hold the Alt-Key and do the Boolean Union then
                      (this is Vectorstylers Combine Mode (Live BoooleanMode))
                      Here the Video
                      He post this in a Tutorial of mine which shows some
                      possibilities of the Combine Mode
                      https://www.vectorstyler.com/forum/topic/1963/easily-editable-arrow
                      • M Online
                        @VectorStyler Okay, I just want to figure out how the fusion effect of adjacent graphics in the halftone effect is achieved, and it feels similar to the effect in the video, so I put forward a suggestion.
                        • M Online
                          monsterfox @Subpath
                          @Subpath Thank you for the tutorial link. I will try the halftone effect and see if the graphic fusion works.
                            @monsterfox Similar steps as in the video, but you have to expand the repeater.
                            • M Online
                              monsterfox @Subpath
                              @Subpath The effect is not the same as I imagined. 0_1717947713567_mmexport1717947698681.jpg
                                @monsterfox
                                I don't know what you had in mind,
                                and I'm not sure if what was shown in the video
                                is possible with the repeater
                                In the meantime i figure out that the Affinity Designer
                                Contour Tool works a bit different then the VectorStyler
                                Contour Tool.
                                Affinity Designer allows no Color in their Contour Tool
                                which VectorStyler Contour Tool does not offer.
                                To get the Effect shown in the Video in VS your Circle has
                                to have a Stroke and "Use round joins on cusp corners" set.
                                Here a video showing the principle in VS.
                                It also takes a bit more work to do this with the Contour tool
                                in VectorStyler than manually. But on the other hand, the
                                Contour Tool produces interesting results.
                                  @monsterfox
                                  I gave the Repeater a go
                                  Repeate Circles with a Contour and
                                  "Use round joins on cusp corners" set like this
                                  Reduce the Space between them (in Repeater)
                                  to get the Effect
                                  Expand the Result from Repeater and
                                  delete the Circles you dont want to process.
                                  Select the circles and do a Boolean Add.
                                  • M Online
                                    monsterfox @Subpath
                                    @Subpath Really thank you for your enthusiasm. I have mastered the effect in your video. The effect I imagined should be like the bitmap in Photoshop, the halftone effect, and the circle graphics above 50 degrees of gray will fuse until 100 degrees of black.Their fused state is based on the current graphic, but my effect picture is not the same. The fused area is in a plum blossom state.
                                      Subpath @monsterfox
                                      @monsterfox
                                      Thank you, I don't see that as enthusiasm. When I saw your video,
                                      I remembered that Encart had already shown something similar.
                                      As far as I know, this fusion effect only works well with shapes of the
                                      same size. So I don't know how your idea could work.
                                      • L Offline
                                        Li Xiao @Subpath
                                        @Subpath
                                        He wants to create Euclidean halftone using the Fusion Ball method. Currently, Repeater and Fusion Ball cannot achieve this. We are looking forward to version 1.3 to see if it can be done.
                                        Euclidean dot (Transforming Round Dot): Round/Square/Round
                                        https://workflowhelp.kodak.com/download/attachments/229783381/worddava24f2bf877b5355acdd16d960264293a.png?version=1&modificationDate=1686070462915&api=v2
                                          Subpath @Li Xiao
                                          @Li-Xiao
                                          In my opinion, the fusion effect is not suitable for replicating something like this.
                                          Because it only works well with shapes that are the same size and an contour/outline is needed.
