Software interoperability
 Illustrator,inkscape,Both graphics and paths can be pasted into VS, but there is a problem: if the copied graphics or paths do not have color information (neither stroke nor fill has color), pasting them into VS will result in the loss of the paths. I hope this issue can be fixed. Also, when pasting into VS, all the content will automatically be grouped together. Although not a major issue, it would be great to solve this too, thank you.
 @monsterfox One thing I do like about importing vectors into VS is that after the initial ungroup, each color is in it's own sub-group. this is really handy for getting rid of unwanted colors quickly
 @monsterfox said in Software interoperability: pasting them into VS will result in the loss of the paths I will try to fix this.
 @VectorStyler Can the two problems in the post be solved?
 @monsterfox Pasting empty shapes from illustrator should work now. I will try to find the solution for the inkscape case also.
 But, the grouping will remain. When pasting from other apps, the graphics get through a format (PDF for AI, SVG for inkscape) and that is imported as a group.
 @VectorStyler It has been tested today. For colorless graphic paths, they will still disappear when pasted into VS(AI).
 @monsterfox said in Software interoperability: For colorless graphic paths, they will still disappear when pasted into VS(AI). What is the AI version?
 @VectorStyler 22.0.1
