    Artboard Guidelines only visible on first row artboards
    7 Posts 2 Posters 6.0k Views 2 Watching
    • H Offline
      Harry
      Despite enabling "All Artboards on Canvas", there are guidelines visible only on horizontal artboards:
      1. How to enable guidelines on all artboards?
        2 In Artboard Options / Guidelines and in Guidelines Panel - could we enable sorting guideines ascending / descending by clicking on X, Y or Angle grey field?
        It would be useful when working with many guides.
        VectorStyler @Harry
        @Harry The visibility seems to be a bug, send me the file with that grid of artboards where the guidelines are not visible.
        I will add (2) in the backlog.
        H 2 Replies Last reply Reply Quote 0
        • H Offline
          Harry @VectorStyler
          File sent by email.
          @VectorStyler said in Artboard Guidelines only visible on first row artboards:
          • H Offline
            Harry @VectorStyler
            @VectorStyler Apart from guideline sorting, it would be great if we could change their parameters in bulk at once.
            For example:
            • select a few guidelines at once (with Shift or Ctrl key) and change their X, Y or Angle
            • select the whole X, Y or Angle column like in Excel and modify its value for all guidelines, etc.
              VectorStyler @Harry
              @Harry said in Artboard Guidelines only visible on first row artboards:
              Would this be in the Guidelines panel or on the Canvas?
              Not clear how this would work (except maybe for Angles). So if we have a bulk of vertical guidelines changing X pos would set the guidelines at the same position?
              H 1 Reply Last reply Reply Quote 0
              • H Offline
                Harry @VectorStyler
                Ok, this idea wasn't good ☺
                What I want to achieve is to set a few guidelines in Artboard options / Guidelines to have the ability to change guidelines quickly for all artboards at once (like 100 book pages etc.) So far I have managed to do it only if artboards are in one row.
                Also, angled guidelines work differently than I expected. If one artboard is 1000x1000 pt, then every artboard should have the same guidelines in the same spot:
                But it seems like those are canvas guidelines and not artboard guidelines:
                  VectorStyler @Harry
                  A fix for this bug will be in the next build.
