    Node selection problem
    5 Posts 3 Posters 4.6k Views 3 Watching
    • AyoA Offline
      Ayo
      Is there a setting that allows me to select multiple nodes of multiple objects simultaneously? A kind of 'pseudo topological editing'.
      While trying to modify a coastline with the Node Tool.
      See: https://recordit.co/sSjGTiw94E
        Subpath @Ayo
        @Ayo
        try "select nodes from all objects" in Settings > Path editor
        but be careful not to use Cmd+a for selecting all nodes then 🙂
        AyoA L 2 Replies Last reply Reply Quote 1
        • AyoA Offline
          Ayo @Subpath
          @Subpath said in Node selection problem:
          THANK YOU! Glad, that works. ☺
          Then the Cmd-'A' indeed...
          Read my post 'Select All Objects while working in the Node Tool'
          https://www.vectorstyler.com/forum/topic/3667/select-all-objects-while-working-in-the-node-tool
          • L Offline
            Li Xiao @Subpath
            @Subpath @Ayo You don't need to enable "select nodes from all objects" to achieve what you want.
            https://youtu.be/LWgl2NLBC4g
            AyoA 1 Reply Last reply Reply Quote 2
            • AyoA Offline
              Ayo @Li Xiao
              @Li-Xiao
              OK!
              The 'Shift' does the job also.
              But I think I prefer "select nodes from all objects". Faster and fewer errors (include previously covered points).
              Thanks.
