    Copy Option/drag object constraign angle 45 degrees.
    5 Posts 2 Posters 4.8k Views 2 Watching
    • AyoA Offline
      Ayo
      When copying object by Option/drag and holding the Shift, I get the constraign angles 0 and 90 degrees. 45 doesn't work.
      Am I missing a setting or is this not supported?
        VectorStyler @Ayo
        @Ayo When moving (or copying) objects, the Shift constrain is always vertical or horizontal. 45 degrees is not supported.
        AyoA 1 Reply Last reply Reply Quote 0
        • AyoA Offline
          Ayo @VectorStyler
          @VectorStyler said in Copy Option/drag object constraign angle 45 degrees.:
          is always
          Oh... 'always' within Vectorstyler then.
            VectorStyler @Ayo
            @Ayo I will add the diagonal case.
            AyoA 1 Reply Last reply Reply Quote 2
            • AyoA Offline
              Ayo @VectorStyler
              1.1.095 Simple but feels much better now.
              Thanks
