Has the "node removal curvature" been altered some?
It could just be me, but the node removal curvature feels different in the last couple builds than before. The resulting curvature feels like to retains less of the original curve prior to removing nodes than before. I checked and I do have the setting "Adjust node removal curvature" checkmarked
Just to give an example - here I am correcting some strokes in outline mode. Removing nodes seems to make it very flat instead of retaining some of that curvature like before. I feel like i have to do more work than before to get them where they need to be in terms of curves
Here is another example from the same file where this time, I have the "node removal curvature" turned off in the settings.
I notice a difference between having the setting on compared to off, but it's not as drastic as it once was - at least to me -
@Boldline I will check this with the previous versions also.
@VectorStyler thank you!
@VectorStyler I reinstalled a couple older builds (73 and 80) and tested the same file in both and I'm getting similar results to build 85. Perhaps it's just something I'm imagining. Or perhaps it has to do with the kind of art I am working with. I appreciate you checking regardless. thanks!
