Mask: create & duplicate ??
I thought I could achieve what I wanted by masking what was outside the text.
I thought I had created a mask from the text and reversed it. I saved the mask and thought I had applied it to the design under the text... it doesn't work the way I want it to. Is this possible? Thank you very much.
Edit: it's working as intended by other ways but I would like to understand how to create a mask and copy it on several layers. Thanks !
@Pat Was this using the Transparency Content object role? There might be a bug here.
@VectorStyler No, it was through the "Transparency" panel.
