Wrong object position when pasting on new layer
I'm not sure, is this a bug or not then I post here. Is it posible to paste a object which cut or copy from anothe layer to the same position on new layer
here is my setting
This is the screen recording
https://recordit.co/ywvKQ5EWdGThanks
@mtinra Cannot replicate it here on the Mac.
Sorry to not mention the OS. It's Windows 10
can also not replicate
it works as it should
and past in place
win 10, toobtw you can write your specs in your signature
there is a field in your profil
I have uninstall and reinstall, it is the same result and I think it happen only on cut command not copy
I don't know if reinstalling the Program fix problems related to the Program Settings.
You can also remove the files "workspace.xml" and "settings.xml" from the VectorStyler user data folder.
They are located in:
C:\Username\AppData\Roaming\NumericPath\VectorStyler1.0\vector\data\resources.I recommend renaming the files and placing them in a different folder.
VectorStyler will then create new setting files when the program starts.
If this fixes your problem, send the copied files to VectorStyler (the developer)
so that he can solve the problem.
.Made also a Video here to show copy and cut is working here
so it is probably not a program bug
Here the Video
@mtinra I will try to replicate this.
Yes!, it help. now working like it sholud.
The problem is in "workspace.xml" and "settings.xml", file size of my files are large different from the default one.I put the files on Google drive here:
https://drive.google.com/drive/folders/1NWeNusIYE2JmNCKpU8PBv6wuE9Doa1NX?usp=sharingThank you
@mtinra I tried again with the ones you uploaded on GD, but here it works as it should.
@b77 for me if I put back the old files, it go wrong again. It may has somthing else on my machine to trigger the problem
