    Slabtype text alignment option
    7 Posts 4 Posters 6.1k Views 3 Watching
      I saw this today and felt it would be a great addition to VS at some point when possible.
      Essentially you create several lines of active text and then select them all and run a script that automatically aligns them all to center and sizes up the text to all be the exact same width.
      Here is a link to a script someone created for Illustrator.
      Here is another tutorial showing the same thing referencing the script provided in the first link
      0_1671398813660_a6092b3c-6eee-4a1d-9cec-c5600cbbf233-CleanShot 2022-12-18 at 16.26.20.png
      • encartE Offline
        encart
        @Boldline I could be wrong, but I think I once asked for proportional scaling to be added and it's possible.
        I know it requires a few more clicks, but I think it's quite simple.
        Video
        Edit:
        I have tried recording all actions step by step as an action and assigning a keyboard shortcut, but it does not work well.
        @VectorStyler I have now noticed that the order of the lines has changed on the recording.
        b77B 1 Reply Last reply Reply Quote 3
          @encart totally awesome. Thanks for sharing. I'm glad it can already be done in VS albeit a few more steps. Always great to have multiple options. I think in the long run, things like this would be great as default scripts built in to VS for efficiency
          • b77B Offline
            b77 @encart
            @encart This can be done with an action, no?
            encartE 1 Reply Last reply Reply Quote 1
            • encartE Offline
              encart @b77
              @b77 Unfortunately no. I have just tried it and it comes out a mess. It takes longer to sort out than to do step by step.
              • b77B Offline
                b77 @encart
                @encart Starting from your idea, here is a slightly faster method: https://recordit.co/Zxll0xjgVn
                (Align objects in geometric order' needs to be enabled in the Alignment panel).
                @VectorStyler But it still doesn't let me record the align actions so I can automate it…
                  @Boldline Yes, this is doable with the Alignment panel. It needs maybe more clicks that ideal, will try to improve that.
