Reset Transform
Is it possible to do a reset transform on multiple objects at once, it seems that it only works on one at a time ?
TIA
Neil
@Igull Object menu > Transform > Reset Transform should work on multiple transformed objects.
This command is also found in the menu of the Transform panel.
@Igull If however you want to reset the objects to the initial size, scaling, rotation, etc., you can select the objects
and delete the Transform effect for all of them with one click — this is done from the 'Shape Effects' panel
(Ctrl-S on Mac or Panel menu > Effects > Shape Effects).Quick video here: https://recordit.co/nAmtJF3xdr
@b77 said in Reset Transform:
Yes, that's what I thought, but last night it would only work on one object at a time ???
I've just revisited it this evening - using the same command - on the same file - on multiple objects, and it works just fine
I can't seem to replicate the issue, I was simply using the collider tool to rotate to zero a bunch of parts that had been drawn - more than 50 and it was annoying to say the least
It's not doing it now, but if it does this again, I'll hold you wholly responsible for the problem
Thanks
Neil
