    Center view on pointer
    12 Posts 5 Posters 10.2k Views 5 Watching
    • IngolfI Offline
      Ingolf
      If this is not available in VS, I suggest it. A simple command I can assign a shortcut to that simply centers the view around the point my pointer hovers over.
      I've realized that I do an incredible amount of scrolling with the mouse wheel or space depressed to center my drawing around where my pointer is. It's a ridiculous amount of work that could often be replaced with a single key press.
      🍏 macOS Sequoia Apple Silicon
      b77B VectorStylerV 2 Replies Last reply Reply Quote 1
      • b77B Offline
        b77 @Ingolf
        @Ingolf Zoom to Selection with Cmd-4 could help in the meantime.
        IngolfI 1 Reply Last reply Reply Quote 1
        • IngolfI Offline
          Ingolf @b77
          @b77 said in Center view on pointer:
          In some cases it can be used, true, but not so much in many others where the object(s) in the target area are smaller and VS will zoom in deeper - and maybe even much deeper.
          But thanks 🙂
          • IngolfI Offline
            Ingolf
            It would be perfect if the numeric keyboard was supported by VS for custom keyboard shortcuts, I could imagine that the num keys 5 or / or * would be perfect for me in the center scenario.
              VectorStyler @Ingolf
              @Ingolf Added this to the backlog.
              b77B 1 Reply Last reply Reply Quote 3
              • H Online
                Harry
                While working with mouse, shortcut for this zoom could be for example double mouse wheel click.
                  Subpath @Harry
                  @Harry said in Center view on pointer:
                  Sorry, I would have objections
                  Double mouse wheel click is not comfortable
                  to do with my mouse. So I would avoid that
                  • IngolfI Offline
                    Ingolf
                    I think it should be possible to configure center to scroll-wheel but don't think it should be default and certainly not double clicking the scroll wheel! I never found it natural or comfortable to use the wheel as a button for just single clicking, and certainly not all scroll wheels can be pressed. Sometimes the button is also awful to press. Some mouse drivers also seem to have something assigned to it.
                    Personally I will assign * (from the num pad if possible) to this feature. 🙂
                    • b77B Offline
                      b77 @VectorStyler
                      Since many people have keyboards without a numeric pad (not just laptop users), there should be
                      a way to assign both a key from the numeric pad (let's say, 5) and a key combination (Cmd-5)
                      that does the same for the shorter keyboards.
                      • IngolfI Offline
                        Ingolf @b77
                        Of course - I mentioned the num pad because I don't think it is supported for shortcuts right now. Using + and - for example on the numeric pad is infinitely easier than using +- on a non-us keyboard without num pad.
                        • b77B Offline
                          b77 @Ingolf
                          @Ingolf 👍
                          • IngolfI Offline
                            Ingolf
                            As I wrote in the announcement thread for version .070 centering works perfectly. I assigned they key M for this and I am navigating lightning fast around the canvas now just hitting M to center view now and then.
